Need help in setting up ECLI and Agent inventory
Article ID: 212757
Updated On: 10-19-2023
Autosys Workload Automation
We have installed AE 12.0.01. We are trying to set up ECLI and use AgentInventory.  What credentials are needed?
Release : 12.0
Component : WORKLOAD CONTROL CENTER
ECLI needs a valid credential user that has access to the backend autosys host.
The monitor ID needs to be a valid EEM user that is a member of the WorkloadAutomationAEWebService group AND has access to ALL machines via the as-machine policies in EEM.
