Problem during VSE recording for swagger 2 specs which include x-components
Article ID: 212363
Service Virtualization
During VSE recording for swagger 2 specs which include x-components, encountered exception below:
java.lang.NullPointerException
 at com.itko.lisa.vse.swagger.helper.SwaggerSchemaResolver.getBodyParameter(SwaggerSchemaResolver.java:291)
 at com.itko.lisa.vse.swagger.helper.SwaggerSchemaResolver.resolvePaths(SwaggerSchemaResolver.java:261)
 at com.itko.lisa.vse.swagger.helper.SwaggerSchemaResolver.resolve(SwaggerSchemaResolver.java:31)
 at com.itko.lisa.vse.swagger.SwaggerEndpointImpl.<init>(SwaggerEndpointImpl.java:44)
 at com.itko.lisa.vse.swagger.SwaggerEndpointFactory.create(SwaggerEndpointFactory.java:33)
 at com.itko.lisa.vse.stateful.protocol.http.FromSwaggerProtocolHandler.parseSWAGGER(FromSwaggerProtocolHandler.java:585)
 at com.itko.lisa.vse.stateful.protocol.http.SwaggerPanel.userChoseNewSwaggerEndpoint(SwaggerPanel.java:533)
 at com.itko.lisa.vse.stateful.protocol.http.SwaggerPanel.setSwaggerUrl(SwaggerPanel.java:835)
 at com.itko.lisa.vse.stateful.protocol.http.SwaggerPanel$4.actionPerformed(SwaggerPanel.java:193)
 at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
 at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
 at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
 at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
 at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
 at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:842)
 at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:886)
 at java.awt.Component.processMouseEvent(Component.java:6539)
 at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
 at java.awt.Component.processEvent(Component.java:6304)
 at java.awt.Container.processEvent(Container.java:2239)
 at java.awt.Component.dispatchEventImpl(Component.java:4889)
 at java.awt.Container.dispatchEventImpl(Container.java:2297)
 at java.awt.Component.dispatchEvent(Component.java:4711)
 at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
 at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
 at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
 at java.awt.Container.dispatchEventImpl(Container.java:2283)
 at java.awt.Window.dispatchEventImpl(Window.java:2746)
 at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
 at java.awt.EventQueue.access$500(EventQueue.java:97)
 at java.awt.EventQueue$3.run(EventQueue.java:709)
 at java.awt.EventQueue$3.run(EventQueue.java:703)
 at java.security.AccessController.doPrivileged(Native Method)
 at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
 at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
 at java.awt.EventQueue$4.run(EventQueue.java:733)
 at java.awt.EventQueue$4.run(EventQueue.java:731)
 at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
 at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
 at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
 at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
 at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
 at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
 at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Release : 10.6
Component : CA Service Virtualization
DevTest does not support x-components in Swagger 2 but it is possible to use components in Swagger 3 with DevTest.
