Problems with APPLY of LU00380 and SO12236
Article ID: 212121
Common Components and Services for z/OS
In the process on installing current maintenance for CA Common Services (CCS) 15.0
Running into several issues with the APPLY CHECK.
  1. SO15161 and LO00380 will not apply due to SO14946 not being applied.
    • SO14946 was received with this maintenance but is marked in error status, so was not included with the APPLY.
  2. SO12236 will not apply. Getting MODID ERROR due to SO10303.
    • SO10303 was previously applied.
  3. Other PTFs fail due to the SO12236 failure.
Example of generated messages:
 (1) GIM30209E ** APPLY PROCESSING FAILED FOR SYSMOD LU00380. REQUIRED SYSMODS FAILED OR WERE MISSING.
   GIM35904I    PREREQUISITE SYSMOD SO14946 WAS MISSING.
  GIM30209E ** APPLY PROCESSING FAILED FOR SYSMOD SO15161. REQUIRED SYSMODS FAILED OR WERE MISSING.
 (2) GIM38201E ** THERE IS A MODID ERROR FOR DATA ENTRY CCISSL IN SYSMOD SO12236.
  GIM31901I    SYSMOD SO12236 DOES NOT SPECIFY SO10303 ON THE PRE OR SUP OPERAND. SO10303 IS THE RMID FOR DATA CCISSL THAT
            IS CURRENTLY INSTALLED
  GIM38201E ** THERE IS A MODID ERROR FOR DATA ENTRY CCISSLGW IN SYSMOD SO12236.
   GIM31901I    SYSMOD SO12236 DOES NOT SPECIFY SO10303 ON THE PRE OR SUP OPERAND. SO10303 IS THE RMID FOR DATA CCISSLGW
            THAT IS CURRENTLY INSTALLED.
   GIM38201E ** THERE IS A MODID ERROR FOR DATA ENTRY CCITCP IN SYSMOD SO12236.
   GIM31901I    SYSMOD SO12236 DOES NOT SPECIFY SO10303 ON THE PRE OR SUP OPERAND. SO10303 IS THE RMID FOR DATA CCITCP THAT
(3) GIM30209E ** APPLY PROCESSING FAILED FOR SYSMOD SO15984. REQUIRED SYSMODS FAILED OR WERE MISSING.
     GIM35907I    PREREQUISITE SYSMOD SO12236 FAILED.
     GIM30209E ** APPLY PROCESSING FAILED FOR SYSMOD SO15983. REQUIRED SYSMODS FAILED OR WERE MISSING.
   GIM35915I    CONDITIONAL REQUISITE SYSMOD SO15984 FAILED.
Release : 15.0
Component : CCS390 - CA COMMON SERVICES FOR Z/OS
(1) - Not following SMP/E requirements to satisfy specified PREREQuistes.
(2) (3) - An internal problem caused SO10303 to be accessible to customers for a small window of time. This PTF was quickly withdrawn and replaced with SO12236. Only the APAR (testfix) ST10303 was subsequently defined on the SUP statement delivered with SO12236.
(1) - Specify PTF SO14946 along with LU00380 on the APPLY. Specify BYPASS(HOLDERROR) as it will be needed.
(2) (3) - RESTORE both SO10303 and SO06667. With these restored, PTF SO12236 will APPLY successfully. This PTF includes both ST10303 and SO06667 in its SUP list.
