Spectrum Control Panel will not connect to a remote landscape. SCP-OCP-10040: Could not connect to the Process Daemon on <Server>
Article ID: 211824
CA Spectrum
Spectrum Control Panel ( SCP ) will not connect to a remote landscape.   SCP-OCP-10040: Could no connect to the Process Daemon on <Server_Name>
Release : 10.x / NetOps 20.x
Component : Spectrum Core / SpectroSERVER
Verify both TCP PORTS 65259 and 61904 are opened from the SCP to the Spectrum Server Landscape where processd is running.
