How to rename Automation Engine directory
Article ID: 211328
CA Automic Workload Automation - Automation Engine
Question: What actions need to be taken to rename Automation Engine directory?
Release : 12.X
Component :
Solution 1 (requires AE shutdown):
1. Stop AE processes.
2. Rename AutomationEngine folder.
3. Adjust all the commands for CPs and WPs in ServiceManager Dialog in order for processes to start. See examples below:
Initial Command in SM Dialog: C:\Automic\ServiceManager\bin\..\..\AutomationEngine\bin\UCsrvwp.exe -IC:\Automic\ServiceManager\bin\..\..\AutomationEngine\bin\ucsrv.ini -svc%port%
New command:
C:\Automic\ServiceManager\bin\..\..\AutomationEngine_test\bin\UCsrvwp.exe -IC:\Automic\ServiceManager\bin\..\..\AutomationEngine_test\bin\ucsrv.ini -svc%port%
Initial Startpath:
Changed startpath:
Solution 2 (does not require AE shutdown):
1. Duplicate Automation Engine folder in parallel to the original one while processes are running. Rename it.
2. Make a copy of running CPs and WPs in the SM Dialog (right-click on the Process in SM Dialog -> Duplicate, rename it if needed, but totally optional)
3. Adjust the commands and start paths in SM Dialog same way as demonstrated above in Solution 1 step 3, and start those. That way there will be processes running from 2 different folders. Once copies of all the processes are made, start them from a new folder, and shut down the processes from the old Automation Engine folder; remove them from SM Dialog, delete the old folder afterwards.
No need to adjust the agents, as they are running from C:\Automic\Agents (just an example, but in default set up /opt/automic/AutomationEngine should only have bin and temp directories). Only processes need to be adjusted.
