How to display interface speed overrides in OpenAPI in DX Netops Performance Management
Article ID: 210960
CA Performance Management - Usage and Administration
Release : 20.2
Component : PERFORMANCE MANAGEMENT INTEGRATIONS
When selecting interface properties:
SpeedIn and SpeedOut should be the discovered speeds.
Under the metric portmfs:
im_SpeedIn and im_SpeedOut should be the override speed.
Here is an example of getting a single value for SpeedIn, SpeedOut, im_SpeedIn, and im_SpeedOut for all the interfaces on a device by grouping on interface ID and averaging the override speeds for a device:
