Upgraded to ReporterS500 appliance OS from 10.5.2.2 to 10.6.1.1 and then restart to boot a new image.
After boot Reporter S500's System Management LED turn to umber.
In Reporter 10.5.2.2 that LED was green.
How to fix this LED status?
Reporter10.6.1.1 has unexpected Base OS issue.
This Base OS is detect power supply has problem incorrectly.
The unexpected detection for power supply is harmless event.
So you can ignore this LED status.
Release :Reporter 10.6.1.1
Component : LED
Engineer team fixed this unexpected behavior as Reporter Base OS bug and released Reporter10.6.2.1 on 2021 April 22.
You can fix this unexpected LED issue by Reporter10.6.2.1.
