Errors in AWI (Automation Web Interface) Log
Article ID: 210166
Updated On: 10-11-2023
CA Automic Workload Automation - Automation Engine CA Automic One Automation CA Automic Operations Manager
Since AE/AWI was upgraded to 12.3.4 following problem can be observed.
The AWI log is flooded with the following kind of messages:
Examples
2021-02-02 13:41:53,040 pool-2-thread-272   [ERROR] UAT:20/U40814/OP 287 0000000276676293 +3795 [.content.monitor.gwe.MonitorPlanMediator] - id already exists 276584626/58
2021-02-02 13:41:53,040 pool-2-thread-272   [ERROR] UAT:20/U40814/OP 287 0000000276676293 +3795 [.content.monitor.gwe.MonitorPlanMediator] - id already exists 276584626/59
2021-02-02 13:41:53,040 pool-2-thread-272   [ERROR] UAT:20/U40814/OP 287 0000000276676293 +3795 [.content.monitor.gwe.MonitorPlanMediator] - id already exists 276584626/60
Debug messages (examples):
2021-02-02 13:39:59,923 pool-2-thread-141   [DEBUG] UAT:2200/U45795/DE 13874 0000000276676368 +3551 [amework.core.async.VaadinSessionLockUtil] - Vaadin session is locked. Predicted Cause: com.uc4.ecc.ae.sheet.prompts.PromptsTableView.getObjectProviderList(PromptsTableView.java:353)
2021-02-02 13:39:59,939 pool-2-thread-141   [DEBUG] UAT:2200/U45795/DE 13874 0000000276676368 +3551 [amework.core.async.VaadinSessionLockUtil] - Vaadin session is locked. Predicted Cause: com.uc4.ecc.ae.sheet.prompts.PromptsTableView.getObjectProviderList(PromptsTableView.java:353)
 <error>
 </error>
   <itm id="0000000000001820" value="FAULT_OTHER - Start impossible. Other error."/>
   <itm id="0000000000001823" value="FAULT_POST_PROCESSING - error in post processing."/>
   <itm id="0000000000001830" value="FAULT_ROLLBACK - General error in rollback"/>
There is no impact on the AE, everything even AWI run correctly
Release : 12.3 Component : AUTOMATION ENGINE
This is a bug of the AWI, it is cluttering the logs with useless Information.
This bug is corrected in the following AWI version:
Automation.Engine 12.3.6 -- available.
Automation.Engine 21.0.0 -- available.
