What is required to bring Web Viewer 11.5 completely up to date with maintenance.
Release : 11.5
Component : CA Output Management Web Viewer
Only three fixes are needed to come completely up to date.
SO08456 ACTIVEX CERTFICATE EXPIRED
SO11228 INCORRENT CODEPAGE not currently available on the web, see attached file which should be placed in the scripts subdirectory.
NOTE: Web Viewer 11.5 is EOS 9/31/2021
