Right-Click to Review Does Not Work With Multiple Timesheets
Article ID: 209154
Clarity PPM On Premise Clarity PPM SaaS
Right-Click Context Menu to Review Timesheets is not working with multiple selected timesheets.
Steps to Reproduce:
  1. Modern UX > Timesheets > Timesheets tab
  2. Select multiple 'Submitted' timesheets (using CTRL + click, or using mouse while keeping the button pressed to select multiple timesheets)
  3. Right click on any timesheet of the selection, select 'Approve'
Expected Results: All selected timesheets are approved.
Actual Results: Only one timesheet is approved.
Release : 15.9.1
Component : CA PPM SAAS TIME MANAGEMENT
This is the intended behavior as per the current design. You cannot use the context menu to approve multiple timesheets. Use the bulk actions instead.
Review, Approve and Return Submitted Timesheets
