Periodically the Automation Engine logs and messages window display:
20210203/125528.596 - U00015006 System forced memory trace dump.
20210203/125528.846 - U00015006 System forced memory trace dump.
20210203/125528.846 - U00003631 Dump caused by:
20210203/125528.846 - U00003513 UCUDB: Not all HSTMT have been closed: Number = '1'
20210203/125528.846 - U00011801 Error in Server routine 'UCGENX_R', Server: 'UC4P#WP036' AE system: 'AUTOMIC'.
not all internal SQL statements released handles correctly.
Release : 12.3
Component : AUTOMATION ENGINE
The logging of these messages will be expanded in future versions. This should have no impact on the performance of your Automation Engine
