ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
UIM - Data_engine error code PPM-035 whne enabling TLS1.2
Article ID: 208440
Upon enabling TLS1.2 in the data_engine configuration, when trying to save it  prompted with below error:
Message: Use SQLNCLI11 to configure TLS specific settings
Resolution: Please check PPM Logs for more details
Error Code: PPM-035
Release : 9.0.2 / 20.x
Component : UIM - DATA_ENGINE
Change the provider in the data_engine probe settings to use the SQLNCI11 driver either from IM or Admin console UI
https://techdocs.broadcom.com/us/en/ca-enterprise-software/it-operations-management/unified-infrastructure-management/9-0-2/installing/pre-installation-planning/install-and-configure-your-database-software/microsoft-sql-server/support-for-tls-v1-2-microsoft-sql-server.html
