data_engine error code PPM-035 when enabling TLS1.2 in the data_engine config
Article ID: 208440
Upon enabling TLS1.2 in the data_engine configuration, when trying to save it  prompted with below error:
Message: Use SQLNCLI11 to configure TLS specific settings
Resolution: Please check PPM Logs for more details
Error Code: PPM-035
Release : 9.0.2 / 20.x
Component : UIM - DATA_ENGINE
Change the provider in the data_engine probe settings to use the SQLNCI11 driver either from IM or Admin console UI
