REQUIRED Z/VM SYSTEM MAINTENANCE RULES
Article ID: 208160
VM:Secure for z/VM
Received message VMXACJ0098I while servicing z/VM 7.1
Trying to apply an RSU for z/VM 7.1.  Where we try to execute PUT2PROD and SERVICE ALL commands, we receive the following errors:
VMFSET2760I VMFSETUP processing completed successfully
VMXACJ0098I CP command 'XAUTOLOG BLDNUC ' rejected by NORULE default.
HCPLGA059E XAUTOLOG failed for BLDNUC - incorrect password
VMFSRV1965E Command CP XAUTOLOG BLDNUC SYNCH failed with RC=59
VMFSRV2310W Service restart file, SERVICE $RESTART, has been created due to
            errors. Correct the errors, and restart SERVICE using the
            following command:
            SERVICE RESTART
VMFSRV2760I SERVICE processing completed unsuccessfully
While PUT2PROD SAVECMS
DMSACP726I 493 K released
VMXACJ0098I CP command 'XAUTOLOG BLDCMS ' rejected by NORULE default.
HCPLGA059E XAUTOLOG failed for BLDCMS - incorrect password
VMFP2P1965E Command CP XAUTOLOG BLDCMS SYNCH failed with RC=59
VMFP2P2760E PUT2PROD processing completed unsuccessfully for SAVECMS
Ready(00100); T=12.54/12.97 21:58:13
id
MAINT710 AT VMSOEP1  VIA *
Ready; T=0.01/0.01 22:00:00
XAUTOLOG BLDNUC
Ready(00059); T=0.01/0.01 21:56:06
Release : 3.2
Component : VM:Secure
z/VM 7.1
In general, to ensure you are able to service z/VM, the following VM:Secure Rules should be added:
* REQUIRED Z/VM SYSTEM MAINTENANCE RULES
ACCEPT BLDCMS  LINK * * (NOPASS
ACCEPT BLDNUC  LINK * * (NOPASS
ACCEPT BLDSEG  LINK * * (NOPASS
ACCEPT MAINT    LINK * * ( NOPASS
ACCEPT MAINT710 LINK * * ( NOPASS
ACCEPT MAINT710 AUTOLOG * ( NOPASS
ACCEPT MIGMAINT LINK * * ( NOPASS
ACCEPT MIGMAINT AUTOLOG * ( NOPASS
ACCEPT AUTOLOG1 LINK * * ( NOPASS
ACCEPT AUTOLOG1 AUTOLOG * ( NOPASS
