When trying to right click on Spectrum OneClick console we see errors such as the following:
java.lang.IllegalAccessException: class com.aprisma.util.BrowserLauncher cannot access class com.sun.jnlp.BasicServiceImpl (in module jdk.javaws) because module jdk.javaws does not export com.sun.jnlp to unnamed module @69a67505
at java.base/jdk.internal.reflect.Reflection.newIllegalAccessException(Unknown Source)
at java.base/java.lang.reflect.AccessibleObject.checkAccess(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at com.aprisma.util.BrowserLauncher.openURL(BrowserLauncher.java:543)
at com.aprisma.spectrum.app.client.menu.LaunchBrowserAction$1.performTask(LaunchBrowserAction.java:44)
at com.aprisma.util.thread.CachedThread.run(CachedThread.java:116)
Unsupported Java Version 9
Release : 10.4.1+
Component : Spectrum Core / SpectroSERVER
Spectrum support 10.4.1+ supports AdoptOpenJDK JRE (8u242).
You can, however, use your corporate license with Oracle to run the Oracle JRE and launch the DX NetOps Spectrum Web Start, but it needs to be the Version8 equivalent.
