Requirements:
Moving WPs, CPs, and Automic database in the cloud.
Agents will continue to be on-premise behind a proxy. Are there any problems or requirements with having on-premise agents connecting to the Automation Engine in the cloud?
Release : 12.3
Component : AUTOMATION ENGINE
The requirements in this situation are that:
For specifics on latency requirements between AE and database, please see https://knowledge.broadcom.com/external/article?articleId=219889
