Which SQL Server 2019 components should be installed for a Client Automation 14.0 SP3 environment?
Release : 1403
Component : DESKTOP AND SERVER MANAGEMENT
Install "Database Engine Service" and "Client Tools Connectivity" components in SQL Server 2019.
For the Client Tools, you need to install the SQL Server Management Studio (SSMS), which is a separate download from Microsoft.
