System ID and System Name for XCOM Installation
Article ID: 205626
XCOM Data Transport
What is SYStem ID and System name while installing XCOM in windows. Does it needs any privileges?
XCOM™ Data Transport® for Windows
The SYSID and SYSNAME are used when configuring the Trusted transfers database or getting history records. They are not used with regular transfers to and from Windows. It does not need privileges.
This is not a network name it is an identifier. A "tag"
See the details for this global parameter: SYSID & SYSNAME
