NCM Workflow does not work for Repair Task
Article ID: 202674
CA Spectrum CA eHealth
NCM workflow is enabled.  When a repair task is created it just runs.  It should be set to Waiting Approval.  Instead the task runs and completes.
Release : 10.4.1
Component : Spectrum Core / SpectroSERVER
The workflow code was never created for the Repair task functionality.
This is tentatively scheduled to be fixed in the January release of DX NetOps Spectrum.
