VIEW Problem running SARBCH program - IEC141I 013-20
Article ID: 202374
OM Deliver OM View
when I run the following jcl I'm getting an error message  that looks to be related to a DCB problem, could you please help me to determine the cause of the error and what is the solution?
Error:
IEC141I 013-20,IGG0191A,P4838126,STEP2,REPORT,751B,TSU111,
P48381.CAVIEW.DL12.SAR1.SARUSERS
Thanks
//STEP2    EXEC PGM=SARBCH
//SYSPRINT DD  SYSOUT=*
//REPORT   DD  DISP=(,CATLG,DELETE),DSN=##HLQ.SARUSERS,
//             DCB=(RECFM=FBA,LRECL=133,BLKSIZE=1320),
//             UNIT=SYSDA,SPACE=(TRK,(15,15),RLSE)
//SYSIN DD *
/DBASE NAME=sardb.dataset.name
/LIST USER=*
Release : 14.0
Component : CA View
Error IEC141I 013-20
20 An OPEN macro instruction was issued for a sequential data set using queued access. BLKSIZE is not a multiple of LRECL, or LRECL is 0 with RECFM=FB or RECFM=FBS, or BLKSIZE is not at least four bytes greater than LRECL with RECFM=V.
Please review Report DD and make sure blksize is a multiple of 133.....
REPORT DD
Defines an output data set (normally SYSOUT) into which SYSOUT listing from the LIST function is written.
This statement can be omitted if no LIST control statements are input to the program. If you are not defining a SYSOUT data set, you must code DCB=BLKSIZE=nnn, where nnn is a multiple of 133.
