We are currently doing a new Linux ARD Hub 3.1.1 installation using Docker Container.
See steps from the documentation.
https://techdocs.broadcom.com/us/en/ca-enterprise-software/devops/agile-requirements-designer/3-1/installing/install-ard-hub/install-ard-hub-using-docker.html
While doing the third step in the Docker image import for Keyclock using 'docker pull jboss/keycloak:5.0.0' command
We get the following error
Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)"
What could be the problem for this? Would you know why Keycloack pull doesn't work?
Thanks in advance for your comments, let me know if you need additional information.
ARD 3.1
Component : CA Agile Requirements Designer
The is an environment network issue dealing with the local proxy server.
we can see the following
sudo docker pull jboss/keycloak:5.0.0
https://registry-1.docker.io/v2 : net/http: request canceled while waiting for connection (Client.Timeout while awaiting headers)
-sh:syntax error near unexpected token '('
This will be an issue with your network / proxy setup in your environment.
I would suggest you review the Docker KB article to address the issue of downloading images from behind a proxy server.
https://stackoverflow.com/questions/23111631/cannot-download-docker-images-behind-a-proxy
Should that not help please contact your proxy Admin for help in resolving this.
