One user is unable to see any value for the OBS Unit filter under the Project Management Domain in Advanced Reporting. The only available value is [Null]. The user has been given all of the same security rights as another user who can see the OBS Units, but still the one user is unable to see any values.
Once the user has been granted the additional security rights, the Load Data Warehouse Access Rights job will need to be run. After the job is run, the values on this filter parameter will be available.
Note: The security right that gives the user access to see values in the OBS Unit filter in the Project Management Domain is the Project View right.
