What does the status “Ended” mean while starting the test?
Release : SAAS
Component : BLAZEMETER PERFORMANCE TESTING
The Ended status means that the engine is in the shutdown phase and it reported data as indicated by the green check mark in the Data Received column.
It would be necessary to review the logs on the individual engines of the test to determine why the engines from one Private Location are in the shutdown phase while the engines of the other Private Location are still in the Ready state.
