The Automation Engine stops working due to the Oracle database running out of space.
U00003590 UCUDB - DB error: 'OCIStmtExecute', 'ERROR ', '', 'ORA-01653: unable to extend table <TABLE_NAME> by 128 in tablespace UC4_DATA'
Missing space in the Oracle database.
Release : 12.n
Component : AUTOMATION ENGINE
To resolve this issue, increase the size of the tablespace in the Oracle database by doing the following:
Add one or more files to the table space using the following command in Oracle:
ALTER TABLESPACE '< Tablespace name >' ADD DATAFILE '<path>' SIZE < size of the file >
ALTER DATABASE DATAFILE '< Datafile name >' RESIZE < size of the file >
