WASP will not start for fresh OC 20.3 install - Max. restarts reached for probe 'wasp' (command = <startup java>)
Article ID: 201239
Hello,
    I just installed a PH, RH and UMP on 20.3. On the UMP I am unable to get WASP started. The log only shows
Oct  9 17:47:15:615 [4672] Controller: Max. restarts reached for probe 'wasp' (command = <startup java>)
I did a VM restore and re-installed UMP fresh again and am getting the same error.
Release : 20.3
Component : UIM - OPERATOR CONSOLE
It was related to a double quotes (“) in my cryptkey path:
cryptkey = “d:\nimsoft\security\certificate.pemm”
and it started to boot correctly when I switched to
cryptkey = d:\nimsoft\security\certificate.pem
