ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Power Supply status metric is not being collected.
Article ID: 200735
CA Infrastructure ManagementCA Performance Management - Usage and AdministrationDX NetOps
We have a device that has a threshold rule setup for power supply status.
The device is not collecting any data on this metric.
Release : 3.7
Component : IM Data Aggregator
The Vendor cert being used is "Cisco Sys Environment Power Supply" Power Supply Status is not a supported metric in this vendor certification.
