Prlblem:
When user runs installDA.bin script for Data Aggregator, got this error for Pre-requisite Checking. The error message is:
Error code: 1
Description: unable to execute test to verify db connection;cause:
[Vertica][VJDBC](100176) Failed to connect to host host-I51644 on port 5433.
Reason: No route to host
Workarond:
- Make sure the the hostname and ip address for Data Repository is correct.
- Turn off the firewall on both Data Aggregator and Data Repository via running these linux command:
service iptables save
service iptables stop
chkconfig iptables off
To verify the firewall on linux been turned off, run this command:
service iptables status
- If the firewall been stopped, it will shown like this:
[[email protected] ~]# service iptables status
Firewall is stopped.
- If the firewall still running, it will shown like this:
Table: filter
Chain INPUT (policy ACCEPT) num target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
- Rerun the Data Aggregator installation script installDA.bin to continue the installation.
