Unable to add the Anomaly Detector to NFA console.
Release : 10.0
Component : NQRPTA - REPORTERANALYZER
In this scenario the not all prerequisites were installed. Uninstall AD verify the prereqs are meet. Reinstall AD, now try to add AD to the NFA console.
The Anomaly Detector prereqs are the same for NFA:
Configure Data Execution Prevention (DEP)
Install .NET Framework
Install IIS, ASP, COM+, and SNMP
Configure SNMP on Windows Servers
Disable IPv6 Connections on Windows Servers
Firewall Configuration
Web Browser Support
Configure Regional Settings
Full pre-req details for NFA/AD r10.0 details are available here:
https://techdocs.broadcom.com/us/en/ca-enterprise-software/it-operations-management/network-flow-analysis/10-0-0/installing/system-recommendations-and-requirements/windows-servers.html
