ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Running ApplyAgentPATCH.sh returns CA_SCM_HOME is not defined
Article ID: 199370
CA Harvest Software Change ManagerCA Harvest Software Change Manager - OpenMake Meister
When upgrading the 32-bit SCM Agent on Linux to 13.0.4, every step completed successfully until the last one. When we executed "./ApplyAgentPATCH.sh" the scirpt failed with the error message "CA_SCM_HOME is not defined". But "echo $CA_SCM_HOME" proves that the environment variable is defined and set to the correct folder:
Release : 13.0.3
Component : CA Harvest Software Change Manager
We were not able to find the root cause of the problem but found if we added the following 2 lines to ApplyAgentUPDATE.sh it resolved the problem:
