User reports that report dates are displaying as DD/MM using Edge Chromium, but display as MM/DD with Edge, IE and Chrome.
Release : 1.5 2.0
Component : CA DYNAMIC CAPACITY INTELLIGENCE
Microsoft Edge date was set to English UK format
DCI was using the setting within Edge. The date format was set in Europe and was set to English-UK. Once changed to English - US the date displayed as expected.
Refer to the Microsoft Edge Chromium documentation on setting the date display format
