Certain configuration items can cause unexpected results when configuring cdm (enhanced profiles). Below are the recommend setting when setting a group up with a cdm (enhanced) mcs configuration.
Release : 9.2.0
Component : UIM - MON_CONFIG_SERVICE
Controller on each machine needs to be set with:
-Set specific name [override]
-Set QoS source to robot name instead of computer hostname (checked)
Settings in Setup cdm (Enhanced) of the mcs configuration
Under General Alarms and QoS Metrics Settings
-Send Short Name for QoS Source (checked)
-Allow QoS Source as Target (checked)
Under General Settings for CPU Monitoring
-Set QoS Target as Total (unchecked)
Under General Settings for Memory Monitoring
