API Gateway: Need Help to Purge Audit Details on Oracle Database
Article ID: 197695
CA API Developer Portal CA API Gateway CA Mobile API Gateway Layer7 API Security
Do you have a routine to purge audit details on an Oracle Database?
API Gateway: 9.4
We don't have any documentation in regards to purging data from external, non-MySQL databases.
