Project Actuals and ETC Show Zero in Project task in New UX
Article ID: 197038
Clarity PPM SaaS
Project actuals and ETC shows in Zero or FTE format in Project taks in new ux.
Release : 15.8
Component : CA PPM SAAS APPLICATION
Project Task page in new UX derive data from the General setting from user account, So if FTE is selected it will show as 0 or 0.6 or 1 in the actuals in task of the project . Change the general page setting to hours , post which it shows the correct data.
