Trying to monitor an IIS server using the APMIA Webserver monitor extension installed on the same system as IIS. The configuration has all been completed as per the documentation and when we use the browser we can see the iis-stats.html page however the agent is unable to get the data and the log shows the following error
7/27/20 10:44:45 AM BST [ERROR] [IntroscopeAgent.WebserverMonitor.WebServerMonitorEngine] Could not get metrics from server : https://myserver.mydomain.com:12001
java.net.SocketException: Connection reset
Network tracing showed that the connection reset was coming from the IIS server
The problem was also found to occur when trying to open the page using a browser located on the agent/IIS system but only when using the FQDN or localhost in the URL - if the IP address of the server was used the connection was maintained.
Release : 10.7.0
Component : APM Agents
The configuration for the IIS server in extensions\Webserver-monitor\config WebServerConfig.xml was modified to use the IP address of the server i.e. changed from
<WebServer Type="Microsoft-IIS" Enabled="true" ServerURL="https://myserver.mydomain.com:12001" Protocol="SSL" Mode="Non-Permissive" DisplayName="MyApp" MetricsURL="IISPerStats"/>
to
<WebServer Type="Microsoft-IIS" Enabled="true" ServerURL="https://10.10.10.10:12001" Protocol="SSL" Mode="Non-Permissive" DisplayName="MyApp" MetricsURL="IISPerStats"/>
