Release : 9.2.0
Component : UIM - SNMPCOLLECTOR
Some probes automatically discovery systems. But in USM, the OS of devices such as switches, routers, etc., when upgraded, are not automatically discovered and reflected in USM.
If you want automatic discovery in USM, you need to schedule discovery to update one or more system components automatically via the Discovery Wizard using the Schedule tab.
View Discovered Systems
