My scramble DB connection in FDM does not reload after saving. The connection profile are saved at location C:\Users\ABC7925\Documents\FDM. Can you please advise why?
Screenshot attached.
Java version might be the cause of the issue. FDM is installed with its own Java. But you might have another version in the environment.
Look under ProgramFiles/Java folder for different versions of Java installed.
Release : 4.9
Component : CA Test Data Manager
Looking at FDM logs ( C:\%AppData%\Roaming\Grid-Tools\FastDataMasker\Logs) we saw that the Java Version used is : 11.3 even though JAVA_HOME is set to OpenJDK1.8.0.212
ProgramFiles\Java folder had
JDK 1.8.0.253 and JDK 11.
To fix this issue , We had to un-install JDK 11 and restart FDM and the connections are now showing fine.
