ACF2/CICS Problems with CICS connecting to MQ
Article ID: 195688
ACF2 ACF2 for z/OS ACF2 - MISC
Having a problem with CICS connecting to MQ, and in the error msgs the EIBRESP  and EIBRESP2 values are indicating the userid for the transaction start request is
not found in the ESM. The ACFRPTOM report has this
R_kerbinfo  CICTQ999 OMVSDGRP   111111  99999999   8  8  32
07/07/20  20.189   13.25.15 CICS999     SYSZ     SYSZ
Failed - Profile specified does not exist
Function: Get user information    Userid:
Release : 16.0
Component : CA ACF2 for z/OS
z/OS 2.3
PTF SO05647 closed a condition in which the obsolete UNIXOPTS default DFTGROUP was being picked up, after applying the PTF any logonid that uses USS services will require an OMVS GROUP Profile Record assigned.
Problem resolved when client updated the logonid with their default GROUP(OMVSDGRP)
