Description:
Export to PowerPoint a portlet view that includes diamond icons causes the diamonds to bunch up after page 1, instead of being on their correct row.
Steps to Reproduce:
Expected Result: To see each issue with their corresponding priority and schedule icon
Actual Result: Starting on page 2 the priority and schedule icons start to shift up directly below the one above it, so that you may see 2 icons on one row, then some issues will not have their icons as they were shifted up the report
Release: ESPCLA99000-12.1-Clarity-Extended Support Plus
Component:
Solution:
WORKAROUND:
None
STATUS/RESOLUTION:
Resolved in Clarity 13.1.0
Keywords: CLARITYKB, CLRT-59444, icon, e2e, ppt, clarity13resolved.
