Looking for reference to Sysview Performance Management Option for Db2 for z/OS (IDB2) DSNWVSER load module but unable to find it.
The DSNWVSER load module was documented in the Insight for Db2 System Reference Guide manual for Release r17.
Additionally the last release that required the DSNWVSER load module was IDB2 r17.
DSNWVSER load module was used to collect Db2 data from the SRV trace output queue with the following parameters:
IFI=NO or IFI=READS and NATURAL-DB2=YES.
These parameters are not supported for IDB2 r18 and later releases as IDB2 now reads all data from the OPx trace buffers.
