ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Automation Engine becomes unresponsive when running Autoforecast
Article ID: 194965
CA Automic Workload Automation - Automation Engine
Under certain conditions running the Autoforecast can cause the AWI to become unresponsive
Each time a forecast is run it leaves an entry in the Process Monitor perspective. Over time they build up. If there are a lot of records the system will become unresponsive when running a forecast
1. Open AWI and choose the Process Monitoring perspective
2. On the left panel click on Forecasts
3. Check if a large number of forecasts are present.
4. Delete all old forecasts
