Why is the updated WebSphere service pack level (WebSphere level 8.5.5.16 and later) triggering what appears to be a persistence problem between DVIPA, IDS, and the WebSphere servers HTTPS communications from the OM Web Viewer 12.1 application when the Load Balancing is being used?
SourceId: com.ibm.ws.runtime.component.ThreadMonitorImpl
ExtendedMessage: Thread "WebSphere WLM Dispatch Thread t=008aae88" (00000093) has been active for 691977 milliseconds and may be hung. There is/are 2 thread(s) in total in the server that may be hung.
at com.ca.erm.webviewer.data.RepositoryBean.isConnected(RepositoryBean.java:852)
at com.ca.erm.webviewer.control.RepositoryDetailBean.isShowFileUpload(RepositoryDetailBean.java:725)
at sun.reflect.GeneratedMethodAccessor346.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55)
at java.lang.reflect.Method.invoke(Method.java:508)
at com.sun.faces.el.PropertyResolverImpl.getValue(PropertyResolverImpl.java:79)
at com.sun.faces.el.impl.ArraySuffix.evaluate(ArraySuffix.java:167)
at com.sun.faces.el.impl.ComplexValue.evaluate(ComplexValue.java:151)
at com.sun.faces.el.impl.ExpressionEvaluatorImpl.evaluate(ExpressionEvaluatorImpl.java:243)
at com.sun.faces.el.ValueBindingImpl.getValue(ValueBindingImpl.java:173)
This is a known IBM WebSphere issue. IBM WebSphere has a known resolution for this situation. There are 2 WebSphere fields that need to be added starting at WebSphere level 8.5.5.16, having to do with the "trustedSensitiveHeaderOrigin"
IBM WebSphere experts had a known resolution for this situation in mind, and it turned out to be the right solution. There were 2 WebSphere fields that needed to be added starting at WebSphere level 8.5.5.16, having to do with the "trustedSensitiveHeaderOrigin"
Fixed links, fixed product names
CR24-NL
Nancy Lipp July 10th, 2024
Part of the broken link initiative
Fixed broken link to IBM
