Timeout Issue with OM Web Viewer 12.1 and IBM WebSphere Application Server
Article ID: 194883
Output Management Web Viewer
Experiencing timeout issues when try to access repositories in OM Web Viewer. DVIPA monitoring during logon shows an almost equal number of packets going to both the XSYS and YSYS LPARs.
Why is the updated WebSphere service pack level (WebSphere level 8.5.5.16 and later) triggering what appears to be a persistence problem between DVIPA, IDS, and the WebSphere servers HTTPS communications from the OM Web Viewer 12.1 application when the Load Balancing is being used?
From IBM WebSphere Application Server team:
SourceId: com.ibm.ws.runtime.component.ThreadMonitorImpl
ExtendedMessage:  Thread "WebSphere WLM Dispatch Thread t=008aae88" (00000093) has been active for 691977 milliseconds and may be hung. There is/are 2 thread(s) in total in the server that may be hung.
at com.ca.erm.webviewer.data.RepositoryBean.isConnected(RepositoryBean.java:852)
at com.ca.erm.webviewer.control.RepositoryDetailBean.isShowFileUpload(RepositoryDetailBean.java:725)
at sun.reflect.GeneratedMethodAccessor346.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55)
at java.lang.reflect.Method.invoke(Method.java:508)
at com.sun.faces.el.PropertyResolverImpl.getValue(PropertyResolverImpl.java:79)
at com.sun.faces.el.impl.ArraySuffix.evaluate(ArraySuffix.java:167)
at com.sun.faces.el.impl.ComplexValue.evaluate(ComplexValue.java:151)
at com.sun.faces.el.impl.ExpressionEvaluatorImpl.evaluate(ExpressionEvaluatorImpl.java:243)
at com.sun.faces.el.ValueBindingImpl.getValue(ValueBindingImpl.java:173)
  • Output Management Web Viewer 12.1
  • IBM WebSphere Application Server 8.5.5.16 and later
WebSphere problem
This is a known IBM WebSphere issue. IBM WebSphere has a known resolution for this situation.  There are 2 WebSphere fields that need to be added starting at WebSphere level 8.5.5.16, having to do with the "trustedSensitiveHeaderOrigin"
IBM WebSphere experts had a known resolution for this situation in mind, and it turned out to be the right solution.  There were 2 WebSphere fields that needed to be added starting at WebSphere level 8.5.5.16, having to do with the "trustedSensitiveHeaderOrigin"
Fixed links, fixed product names
CR24-NL
Nancy Lipp July 10th, 2024
Part of the broken link initiative
Fixed broken link to IBM
