AWA: Job named START in system causes Search for Use Issues
Article ID: 194813
CA Automic Workload Automation - Automation Engine CA Automic Workload Automation - Automation Engine
If a task has been created with the name START, it can generate unexpected behavior if deleted or renamed; it will show usage in other objects within the Automic Web Interface
Release : 12.3
Component : AUTOMATION ENGINE
This will be fixed in a future release. It is recommended to follow naming conventions to mitigate issues similar to this: https://docs.automic.com/documentation/webhelp/english/AA/12.3/DOCU/12.3/Automic%20Automation%20Guides/help.htm#AWA/Objects/BestPractices/BP_ConsistentNamingConventionsObjects.htm
