Not seeing updated alarms after Notifier restart
Article ID: 194044
CA Spectrum CA eHealth
After restarting Notifier it is noticed that new alarms or clears are not processing
GET_EXISTING_ALARMS=true is set in the alarm resource file (.alarmrc)
Notifier needs to load existing alarms into memory when this option is set.
When there are thousands of alarms this process can take a very long time.
It is advised to turn this feature off in the resource file.
