After a database refresh in PPM SaaS from a Production to Sandbox environment, the DWH jobs are no longer working.
Load Data Warehouse
and
Load Data Warehouse Access Rights
both fail with errors like below
ERROR 2020-06-21 23:44:59,245 [Dispatch Load Data Warehouse Access Rights : [email protected] (tenant=clarity)] dwh.event ETL Job Failed. Log details below:
2020/06/21 23:44:57 - audit table name - & DWH_CFG_AUDIT
2020/06/21 23:44:59 - Oracle? - ERROR (version 5.0.2, build 1 from 2013-12-04_15-52-25 by buildguy) : An error occurred executing this job entry :
2020/06/21 23:44:59 - Oracle? - Couldn't execute SQL: BEGIN
2020/06/21 23:44:59 - Oracle? - DWH_SEC_RIGHT_LOAD(P_DBLINK => 'DWHschemaName_PPMschemaName',
2020/06/21 23:44:59 - Oracle? - P_ARRAY_SIZE => 50000);
2020/06/21 23:44:59 - Oracle? - END;
2020/06/21 23:44:59 - Oracle? - [CA Clarity][Oracle JDBC Driver][Oracle]ORA-20100: ENCOUNTERED EXCEPTION WHILE INSERTING INTO DWH_SEC_RIGHT. SQLERRM : ORA-02019: connection description for remote database not found
2020/06/21 23:44:59 - Oracle? - ORA-06512: at "DWHschemaName.DWH_SEC_RIGHT_LOAD", line 42
2020/06/21 23:44:59 - Oracle? - ORA-06512: at line 2
This is due to the DB_LINK not being named correctly in the sandbox environment after the database refresh.
The Broadcom DBA team has taken steps to refresh their process with the team to ensure this does not happen again in the future with database refreshes.
Release : 15.6.1
Component : CA PPM SAAS APPLICATION
Make sure the DB_LINK is in the following naming format (this is for Clarity SaaS only):
PPMschemaName_DWHschemaName.
