Custom NCM firmware script will not run for devices in Juniper Junos device family.
Article ID: 193840
CA Spectrum
When trying to use a custom firmware script for devices in the Juniper Junos Device family, you may receive the following error:
"2]: Can't open perl script <ip address of device>: No such file or directory".
Furthermore, if you run the same script for devices in a custom device family it will work successfully.
Release : 10.4.1
Component : Spectrum Applications
This is a known issue. Please reach out to Spectrum Support to request the following patch which will resolve the issue.
Spectrum_10.04.01.D39
