Versions: FDM 4.9.21 TDM Portal 4.9.41
Is it possible to encrypt the key stored in the CSV file and to obfuscate it with asterisks when you enter it, perhaps with a confirm field in the UI like a password change?
It could be optional as perhaps not all customers want this?
What I am looking for is that the csv file with the master key installs the master key encrypted and not in plain text. This way the key is not exposed unless in the FDM or Portal screens
PERSONS,CREDIT_LIMIT,FORMATENCRYPT1,,,,,Y,,,,,,,,,,,,,,,Roy,,,,,
