Compatibility of Automation Engine v12.3 to SAP S/4HANA 1709 version and SAP S4/HANA 1909 version
Article ID: 193496
CA Automic Workload Automation - Automation Engine
We are currently running on the SAP S/4HANA 1709 version and there is a plan to upgrade our S4/HANA to 1909 version by end of this year.
The AE version we are running now is v 12.0 and we are planning to upgrade to v12.3.
Is there any dependent additional SAP transport that we need to include during the upgrade to AE v12.3 and will there be additional transport required for S4/HANA 1909 version?
Release : 12.0
Component : AUTOMATION ENGINE
Our SAP Agent is compatible with SAP Basis. The Automation Engine has no compatibility with SAP HANA, which I presume you mean the database.Our SAP Agent is not concerned about which database SAP is running on.
Our AE does not interact directly with underlying sap s4/hana and does not have any insight into /upgrading  SAP S4/ Hana  . You can check our compatibility matrix (shared earlier) for AE compatibility with SAP agent.
Here's the link to our matrix again:
https://downloads.automic.com/tools/compatibility_matrix?compatibility-mode=component&offering_version_id=1570601284526&lifecycle_entity_id=1409143059253&component_id=1409731986657&version_id=1556109341102
If the agent version you are trying to run is compatible, you can check our product documentation for related upgrade information . Here a direct link to the Upgrade section of the documentation :
https://docs.automic.com/documentation/webhelp/english/AA/12.3/DOCU/12.3/Automic%20Automation%20Guides/help.htm#Installation_Upgrade/Upgrade_Intro.htm%3FTocPath%3DInstalling%7CUpgrade%2520Installation%7C_____0
https://community.broadcom.com/enterprisesoftware/communities/community-home/digestviewer/viewthread?MessageKey=8cd7d418-10fa-4411-8193-e4c8dcdfe69b&CommunityKey=2e1b01c9-f310-4635-829f-aead2f6587c4&tab=digestviewer#bm8cd7d418-10fa-4411-8193-e4c8dcdfe69b
