When i make the report server URL as https. It is not working properly. Few seconds was worked after that it got failed and got the below error,
Error 503 - Service Unavailable. The requested service is temporarily unavailable but should be restored in the future. Try again later. If you are still experiencing problems, contact your system administrator.
Additional error:
Failed to get an instance of ClarityJasperAdmin :: Exception getting ClarityJasperAdmin : Unauthorized access to https://www.xxx.com/reportservice with username ppmjasperadmin
Caused by: java.lang.reflect.InvocationTargetException
Even we have deleted and re -created organization in japersoft and reimported everything.
Release : 15.8
Component : CA PPM JASPERSOFT
A) Under Load Balancer Configuration
B) Both URL's (PPM and Jaspersoft was configured under one segment / LB Configuration/Settings)
C) Once separated both PPM and JS urls under LB Configuration/Settings
Resolved the issue
As a workaround used one server name in properties.xml.
