Problem with JS class that are not loaded properly
Article ID: 192996
CA Identity Manager CA Identity Portal CA Identity Suite
After upgrading from CA Identity Manager 12.6.8 to version 14.3 an error appears in the CA Identity Portal.
The error appears when trying to set challenges.
Java Class error.
Release : 14.3
Component : CA IDENTITY SUITE (VIRTUAL APPLIANCE)
The attribute |challengeFlag| could not be loaded into IP.
This is not a CA Identity Manager code issue.  The cause of the error was identified in custom javascript (a JQuery library that was used without jquery).
